Home Solar Wind Water Electricity & Heating Projects DIY Calculators Other
Forums Mailing list Webshop Product info EnergyWiki Links About 24 volt Contact
Swedish English
Other
Pedal PowerFilm
The VelomobileKalkylatorUppdaterad
Torque & PowerKalkylator
Gear & Pully types
Conversion Tables
AWG to mm table
Speed conversion calculatorKalkylator
Joineries
A patio for our cottage
Search for
Torque and Power
The torque (or moment of force) may be calculated using the following formula:
τ = F x r x sinΦ
sinΦ equals 1 if the angle is 90°. If the arm with which the torque is measured is horizontal, the angle may therefore be disregarded. The position vector r therefore equals the length of the arm, between the anchor point of the scales and the centre of the turning axis. The formula may then be written as:
τ = F x r
r (the position vector) is measured in metres and since F = m x g, where m stands for mass in kg and g for earth’s gravity (9.81), you can simplify things greatly for yourself by making the arm 1 metre long. The torque measured in Newton metres (Nm) then equals about 10 times what the scales are showing. Thus, each kilogram will equal 10 Nm.
In order to estimate the torque, use the calculator below. Please note that the arm should be weighed for correct measuring results. Lift the arm to a point straight above the stationary scales, using another pair of scales until it is in a horizontal position. Read the weight and add it to the mass column in the calculator below.
N.B: Use a full stop when using decimals, not a comma!
Position vector (r): metres
Angle (sinΦ): °
Mass: kg
Result:
Torque: Nm
Once you are familiar with the torque at different revolutions per minute (rpm’s) the power is easy to calculate. The formula for power calculation is:
P = τ x n x 2 x pi
τ = Torque
n = roations/ second
pi = 3,14
Torque (τ): Nm
Revs: rpm
Power: Watts
  Torque
Torque Water Wheel
In the picture above the spring weighing scale is hidden behind the rock. When the screws are tightened around the axis of the wheel, the wheel slows and the scales may be read. Then the screws are tightened again followed by a new reading. Repeat and note the rpm of the wheel and the weight on the scales until the wheel is completely still.
Torque and Power
When you have collected all the data you need for torque and effect, it is possible to draw a curve diagram showing effect and torque.
