Home Forums Blog Webstore Manuals Solar Wind Hydro Electricity & Electronics Heating Calculators Projects DIY Other FAQ Links About 24 volt Contact
Home
Forums
Blog
Webstore
Manuals
Calculators
FAQ
Links
About 24 volt
Contact
Solar Power
Solar panelsKalkylator
DimensioningKalkylator
DIY
Solar Air Heater 1
Solar Air Heater 2
Solar Air Heater 3
Thermostat
Solar height
Wind Power
Various Wind Turbines
Wind energi & siteKalkylator
Do It Yourself
Cut in wind speedKalkylator
TurbineKalkylator
AlternatorKalkylatorFilm
Magnets
Charge Controllers
Resistive loads
More about wind power
Hydro Power
Head and flow
Flow measurementKalkylator
Turbine & wheel types
Francis
Kaplan & propeller
Pelton
Turgo
Crossflow
UW-turbines
Water wheels
Undershot wheelsKalkylator
PonceletKalkylator
Zuppinger
DIY
Hydro AlternatorKalkylator
Double electric systems
Ohms lawKalkylator
Cable area & lossesKalkylator
Alternators
Star & Delta windingKalkylator
Stator windings
Charge Controllers
Solar Charge Controllers
Shunt Regulators
What is MPPT & PWM?
Inverters
DC/DC converters
Resistor Color Code
Heating
Water HeatingKalkylator
Heating wire - KanthalKalkylator
Projects
My Water Wheel
The Alternator
Pictures and film clips
Power output
Mixters Francis Turbine
My first Wind Turbine
Wind Wheel
Home built Car & Tractor
Other
Pedal PowerFilm
VelomobilesKalkylator
Torque & PowerKalkylator
Gear & Pully types
Conversion Tables
AWG to mm
Speed conversionKalkylator
Joineries
A patio for our cottage
Ohms law
Enter any two known values and press "Calculate".
Voltage (V): volts (V)
Current (I): amps (A)
Power (P): watts (W)
Resistance (R): ohms (Ω)
Result:
V (voltage) = V (volts)
I (current) = A (amps)
P (power) = W (watts)
R (resistance) = Ω (ohms)
Ohms law
P = power in watts (W)
V = voltage in volts (V)
I = current in amperes (A)
R = resistace in ohms (Ω)
