Home Forums Blog Webstore Manuals Solar Wind Hydro Electricity & Electronics Heating Calculators Projects DIY Other FAQ Links About 24 volt Contact
Solar Power
Solar PanelsCalculator
DimensioningCalculator
DIY
Solar Air Heater 1
Solar Air Heater 2
Solar Air Heater 3
Thermostat
Solar height
Solar Air Heater 1
In total we have now constructed almost thirty solar air heaters during the evening classes we have had here in Vilhelmina. I have participated myself in all of these classes, and have had the privilege to share and learn from all of the participants many ideas. The solar air heaters themselves also improved as time passed and the latest model, seen in the picture below, is really quite good-looking, in my opinion! A further wish would perhaps be for the black sheet metal strips to fully cover the sides of the solar air heater.
Solar Air heater
If you want to build your own solar air heater it is a good idea to spend some extra time thinking about the measurements of the solar heater, in order to keep costs and wastage as low as possible.
The solar air heater in the picture measures 213x123 cm, which gives a surface area of 2.5 square metres and a power of about 1 kW. An equivalent solar heater retails for about 7-800 kr; this one can be built for around 2000 kr and that includes solar panels (6 watt), a fan and a thermostat.
Since we have used polycarbonate sheets instead of glass, the width of the polycarbonate sheets has determined the height of the solar heater. The polycarbonate sheet we chose has a thickness of 4 mm, a width of 210 cm and it is sold by the metre. Using a 6 mm thick polycarbonate sheet would probably provide increased stability, but even then it will probably still sway when it’s windy, so a crosswise, internal strip of metal may also be necessary here. The wooden frame was made three cm wider (1.5 cm on each side) so that the polycarbonate sheet could be lowered into the frame. For the back we chose plywood (12 mm) with a width of 120 cm and since the plywood board also was lowered into the frame the final width of the solar heater was 123 cm.
Solar Air heater Since we had access to a woodwork shop when we were building these solar heaters it was easy for us to saw out the frame within which the polycarbonate sheet and plywood was lowered. Another alternative is to add strips of wood to the inside of the frame.
The frame for the solar heater to the right is made from impregnated wood measuring 45x120 mm, but thanks to the plywood board on the back, the solar heaters were as stable with a thickness of just 28 mm for the wood used in the frame.
After this all you need to do is to insulate the solar heater on the inside and we chose 12 mm asfaboard (tar-based roofing felt). However, we have since found that using roofing felt should be avoided as it spreads a smell of tar inside the house as the temperature in the solar heater rises.
The more insulation you use the better your solar heater will work and it may therefore be worth your while to insulate the insides of the frame too. Through the big hole heat is conducted in to the house via a spiral tube. The opening on the underneath of the solar heater, where air comes in, was covered with a mosquito net. After that it was time to screw on the strips of wood as a distance for the black corrugated sheet metal which is going to go in the box. In the picture you can also see the strip of wood going crosswise and thus stabilising the polycarbonate sheet.
This particular solar air heater conducts the heat into the house from the lower edge of the solar heater. The idea is that the air should be heated on the front of the corrugated sheet metal and then sucked down on the back of it.
Solar Air Heater
Solar Air heater The corrugated sheet metal has a width of 108 cm and that proved to be just right for our solar heaters, so all we needed to do was to buy sheets of the required length. It doesn’t matter whether you place your solar heater standing up or lying down. If you place it lying down one sheet will be enough lengthwise and standing up you use two shorter sheets going across instead. When the sheets of metal overlap you estimate a width of about one metre per sheet. Regardless if you use a standing up or lying down solar panel there will be a gap between the sheet of metal and the frame, both on the upper and lower edges and that’s as it should be. The distance of this gap isn’t critically important, so there was no reason for us to cut the sheets of metal lengthwise in order to obtain a more accurate measurement.
These solar heaters will provide an efficiency of about 40-50% but if you wish to go higher than that you will need to go to the store and spend your hard-earned cash! The solar catchers you find in stores for around 7-8000 kr don’t give off any more heat, they are just slightly smaller. If you require more heat than the 1-1,5 kW (around 1500 kWh from March to August) which these solar heaters will provide, you can always build two and still have plenty of money left to go bowling with your pals.
Solar Air heater Once you have built your solar air heater you’ll probably want it to work as well and for that you need a fan. The fans we have chosen to use are computer fans (12 volt) with outer measurements of 120x120 mm. If you sand down the edges of your fan it is possible to squeeze it into the spiral tube and it will fit so snugly that you won’t need to fasten it with screws or anything.
The fan is provided with electricity from a 12-volt, 6 watt solar panel. This solar panel is made from amorphous silicon and is available for 494 kr including V.A.T at sagitta.se. sagitta.se.
Fan However, the best is yet to come, and I’m not referring to Tommy in this picture, but his thermostat and the really satisfying results he achieved by warming it in his hand. What he did was this: he unscrewed the thermostat from an old disused washing machine and it turned out to be perfect for the solar heater. Also, the knob has a graduated temperature scale so all he needed to do was to set it to the desired temperature.
The fact that Tommy had the potency to squeeze the fan into the spiral tube isn’t quite as large a feat as maintained by his facial expression; others too have succeeded to do it. Accordingly, the female participants weren’t very impressed by this but instead they came up with ideas about how to keep flies away from the polycarbonate sheets. If you use tape over the gaps on the sides of the sheets the flies won’t be able to crawl in to the cells and lay their eggs there. I mean, just imagine a solar heater full of hatching flies in the first spring sun!
Termostat If you don’t wish to rummage around the scrap heap looking for old washing machines a similar thermostat is available from conrad.se for only 139 kr. The thermostat works on both extra low voltage (ELV) and 230 volt alternating current (AC).
Always using a 12-volt fan (even if you have access to 230 volts in your house) with a battery eliminator may be a good idea because you won’t need to call in an electrician to install the fan.
Solar Air heater As one of us tightened a screw another one put the kettle on for some coffee, but now it’s over and it’s been really great. Whether there are enough people interested in continuing the class, I don’t know, but I do know one thing, that building solar heaters is a lot like bowling: all you need is the right touch.
A detailed building instruction can be found here. här.
More pictures available here. ...and here -->
...and here -->
Solar air heaters may also be constructed in a different way, see tompas Solar Air Heater.
