av Croncraft 31 jul 2011 14:00
..made another test coil today, 35 turns gives approx. 2,5VAC @ approx. 60rpm with an airgap of ~7mm each side of the coil. I´m not sure if the airgap affect the voltage or not..? I will narrow it down towards 2mm each side at final test. 2,5VAC x 15coils = 37,5 RMS(RootMeanSquare) volt. 37,5 x 1,414 - 1,4(rectifier loss) = 51,63volts to battery
Did I calculate it right? In case I did, it seems this coil is pretty close to what I will wind. However, I will make one testcoil later when I have the correct wire available.
- Bilagor
- DSC01577.JPG (25.62 KB) Visad 5380 gånger
- DSC01580.JPG (24.88 KB) Visad 5386 gånger
- DSC01579.JPG (24.65 KB) Visad 5382 gånger
- DSC01578.JPG (25.87 KB) Visad 5372 gånger
- HappyCamper=)
- DSC01575.JPG (30.77 KB) Visad 5377 gånger
