Roligheter!
Re: Roligheter!
Inläggav deepforest 02 feb 2012 00:57
Hur orkade du med dessa
Baggis, jag har två tonårsdöttrar....... :roll:
Re: Roligheter!
Inläggav Järnet 09 feb 2012 15:21
Hehehe...
Järnet
Re: Roligheter!
Inläggav tompas11 09 feb 2012 20:17
An engineer was crossing a road one day, when a frog called out to him and said, "If you kiss me, I'll turn into a beautiful princess."
He bent over, picked up the frog, and put it in his pocket.
The frog spoke up again and said, "If you kiss me, I'll turn back into a beautiful princess and stay with you for one week."
The engineer took the frog out of his pocket, smiled at it and returned it to the pocket.
The frog then cried out, "If you kiss me and turn me back into a princess, I'll stay with you for one week and do anything you want."
Again, the engineer took the frog out, smiled at it and put it back into his pocket.
Finally, the frog asked, "What is the matter? I've told you I'm a beautiful princess and that I'll stay with you for one week and do anything you want. Why won't you kiss me?"
The engineer said, "Look, I'm a busy engineer.
I don't have time for a girlfriend. But a talking frog, now that's cool!"
tompas11
Re: Roligheter!
Inläggav Järnet 15 feb 2012 21:21
Järnet
Re: Roligheter!
Inläggav tompas11 15 feb 2012 22:18
An old man walks into the barbershop for a shave and a haircut, but he tells the barber he can't get all his whiskers off because his cheeks are wrinkled from age.
The barber gets a little wooden ball from a cup on the shelf and tells him to put it inside his cheek to spread out the skin.
When he's finished, the old man tells the barber that was the cleanest shave he's had in years.
But he wanted to know what would have happened if he had swallowed that little ball.
The barber replied, "Just bring it back in a couple of days like everyone else does"
tompas11
Re: Roligheter!
Inläggav tompas11 17 feb 2012 16:26
tompas11
Re: Roligheter!
Inläggav Karro 18 feb 2012 13:43
Att hitta tappade skruvar.
1) Skruven behövs inte: Gå över golvet i valfri riktning barfota eller i strumplästen, och skruven hittas garanterat när man trampar på den och det gör ont.
2) Skruven behövs: Ge upp med en gång och plocka fram en ny ersättningsskruv. När skruven på detta sätt är permanent ersatt och tillbakaskruvad kan skruven hittas som i första fallet.
Re: Roligheter!
Inläggav Karro 18 feb 2012 13:47
Att hitta en katt om man är närsynt med glasögon:
Lägg helt enkelt glasögonen på bordet bredvid dig och gör något helt annat, som att checka 24volt. Mycket snart kommer katten och sätter sig på glasögonen.
Motmedlet mot detta, dvs. om du inte vill hitta katten, är att lägga glasögonen någonstans där katten inte kommer åt. Men då kan du sedan famla omkring i rummet och försöka hitta glasögonen.
Ett annat sätt att hitta en katt är att skriva något på tangentbordet, eller läsa internet. Mycket snart finner man att katten sätter sig ovanpå tangentbordet framför skärmen.
Min katt sitter just nu till vänster om mig och försöker bestämma sig för om den ska ta ett steg framåt till tangentbordet. Jag överlistar den genom att sluta skriva nu.
Re: Roligheter!
Inläggav Järnet 18 feb 2012 14:12
Hahaha... för jäkla bra Karro! Tar mig friheten att förmedla dessa ord vidare!
Järnet
Re: Roligheter!
Inläggav tompas11 18 feb 2012 18:30
tompas11
Re: Roligheter!
Inläggav Karro 18 feb 2012 19:11
Jag har en katt som är precis sådan.
Re: Roligheter!
Inläggav deepforest 18 feb 2012 22:29
Jag har 2 :roll:
Försök läsa en tidning......
Re: Roligheter!
Inläggav Järnet 18 feb 2012 23:27
Jag har 2 :roll:
Eller skriva på datorn. Min katt älskar att sitta på tangentbordet.
Järnet
Re: Roligheter!
Inläggav Järnet 20 feb 2012 22:32
Järnet
Re: Roligheter!
Inläggav Järnet 21 feb 2012 11:43
Järnet
Återgå till Fritt forum
